Are the Template back in MF5 Plus?.
shspvr
Post by shspvr »
Before Plus there was only 3 Template did they add the back in and did ever fix copy utiliy which still lack the able to lable a disc before burning.
htchien
operating_system: Mac
Post by htchien »
I believe there are more than 3 DVD templates in DVDMF 5 standard. If you bought DVDMF 5 online (which is the download version) then you should get the purchase receipt mail from Element 5 and in that mail you should be able to find a download link to let you download the extra menu templates and components.
In DVDMF 5 Plus the numbers for menu templates are:
SmartScene DVD Menus: 12
Text DVD Menus: 11
Thumbnail DVD Menus: 11
High Definition Menus (for HD DVD): 5
Total: 39
You can also get free template pack from http://www.ulead.com/download/freegoodies.htm
For the Disc Label issue of the Copy Disc utility, it's still not opened in DVDMF 5 Plus. When you copy a disc usually the disc label of the source disk will be copied to the destination disk. Is there any reason to offer you the option to change the disk label? (sorry for my bad memory if you already mention it in somewhere else)
Best regards,
H.T.
Ted (H.T.)
shspvr
Post by shspvr »
Oh i think it was the trial ver that did come any when frist install it a long go that why I ask about the templates
Yes becuase I keep track of them in data base after using dvd shrink them to fit the disk like episodes show name and disk number
htchien
Post by htchien »
shspvr wrote:Oh i think it was the trial ver that did come any when frist install it a long go that why I ask about the templates
Trial versions always get limited templates.
Then I think it's a task that DVD Shrink should offer because the disk is made by DVD Shrink.
In Ulead Copy Disk utility it does not offer the fit-to-disk (shrink) feature but InterVideo DVD Copy 4, which is also included in DVDMF 5 Plus, does offer that feature. And IVI DVD Copy 4 also supports to let you type the disc label before disc copying / shrinking. Maybe you can give DVDMF 5 Plus / InterVideo DVD Copy a try?
http://www.ulead.com/dmf/
However InterVideo DVD Copy cannot remove the copy-protection in DVD and it will stop copying / shrinking the disk if it found the copy-proection is existed in the DVD.
H.T.
Ted (H.T.)
shspvr
Post by shspvr »
It dose but I had problem with it and newer ver of nero.
Now that be a nice feature build in DVD MovieFactory for one shot deal and as for InterVideo DVD Copy it is far slower then DVD Shink and not as good as DVD Shink and lots useless junk in DVD Copy I never use like trasoncoding stuff.
