Install C3DPS to E:?
richardnau
Post by richardnau »
After a major crash, I've just done a big upgrade and rebuild of the computer. For reasons too detailed for this post, Windows has been installed onto E:.
I've reinstalled almost all my software (inc MSP8, DVDMF, VS10) - but C3DPS just won't install. When I run the installer, I just get a message in the DOS box that says: Program too big to fit in memory.
Reading between the lines of other posts, I suspect that I've struck trouble beceause there is no C: to install onto (it's a DVD burner).
Am I right? Does anybody know how to install C3DPS onto other than C: ?
Thanks,
Richard.
Video editing PC:
C2D E6600 CPU on Asus motherboard
2GB dual channel DDR2 RAM
7600GT PCIe video card
320GB RAID 1 SATA system drive
400GB RAID 1 SATA documents drive
400GB video drive
Samsung and Pioneer DVD burners
Vista Home Premium 32 bit
htchien
operating_system: Mac
Post by htchien »
It will install other than C: because I install it in D:.
Please go to Microsoft Windows Update website ( http://windowsupdate.microsoft.com ) and update the Windows Installer component of Windows to see if it works. The default Windows Installer component of Windows is v2.0 and is needed to be updated to v3.0 so some softwares can be installed properly.
Hope this helps.
H.T.
Ted (H.T.)
richardnau
HT,
Thanks for the suggestion.
I'm using a fresh (clean) WinXP install with ALL updates applied. I already have Windows Installer 3.1 (v2) installed.
Any other ideas?
Richard.
Video editing PC:
400GB video drive
htchien
Post by htchien »
Ted (H.T.)
richardnau
Thanks again, HT.
I've reviewed those posts/threads, but they really don't seem to describe the situation I'm in. I've had no viruses, memory is all working fine. Everything else on the PC is working fine. All apps working fine.
The more I tinker, the more I really think I've got a problem with the fact that there is (currently) no writable C: on my system. I reckon that there's probably something hard-coded into the C3DPS installer that is looking for C: - even if only as a temporary place to unpack files before installing them somewhere else.
I've pretty much talked myself into the fact that I'll just have to do (another :( ) clean install of Windows, but making sure that the OS gets onto C: this time, if I want to use C3DPS again (and I do). I know that I can do this as I have recovered all the files off the old (damaged) C: - so it's not lurking in the system any more.
Curiously, as I have reinstalled every other app on the machine, everything has managed with the no C: situation apart from C3DPS (installer won't run) and PhotoImpact 11 (installer runs OK, but app stalls every time when loading u32ico.fio).
[We've discussed C3DPS on this thread, and there have been a number of threads on the PI forum discussing the u32ico.fio issue. For many people, this issue seems to have revolved around allocation of administrator privileges - but I only have 1 user set up (as administrator), so that can't be the problem. One other user seems to have associated the issue with a non-C: install, and to have fixed it by re-installing Windows...]
I just wish that I had come to this conclusion last week - and that I had planned to install the Ulead apps first after the rebuild, not last!
(BTW: MSP8, DVDMF5 and VS10+ have all installed fine on the system...)
Thanks again. I'd still love to hear if anyone has a brainwave. Otherwise, next Friday night promises to be a long one...
Richard.
Video editing PC:
400GB video drive
richardnau
By the way, HT, I know you said you had installed C3DPS on D: -- but do you have a C:? That might explain why it worked for you but not for me... (I have no C:)
Video editing PC:
400GB video drive
htchien
Post by htchien »
Yes, I have drive C: with Windows XP Pro SP2 installed.
Hope this helps.
H.T.
Ted (H.T.)
richardnau
HT,
Well, it helps me think my hypothesis (lack of C: is the problem) is correct.
Thanks.
Richard.
Video editing PC:
400GB video drive
richardnau
Well, I've done the Windows re-install, and all is running smoothly.
PI 11 reinstalled just fine this time and is running like a train.
But I'm having the smae problem with C3DPS. So I've taken the last resort step of raising a tech support request. I'll post again when it's all worked out.
Video editing PC:
400GB video drive
richardnau
With the help of Ulead Support, I have re-downloaded the product and all is working again. Not sure whether I had a corrupted file or whether it was a problem with the 'upgrade' installer. Either way, all systems now GO.
(Thanks HT for help and support.) :D
Video editing PC:
400GB video drive
Xyzzy2
motherboard: MSI Z77MA-G45
processor: Intel i5-3570K
ram: 8 GB
Video Card: MSI R7770-2PMD1GD5 OC
sound_card: Realtek 892
Hard_Drive_Capacity: 6.25 TB
Monitor/Display Make & Model: HP ZR24w
Post by Xyzzy2 »
richardnau wrote:Well, I've done the Windows re-install, and all is running smoothly.
Just out of curiosity- did you try to assign to C: some hard drive when solving your problem?
X.
richardnau
No. Perhaps it would have worked if I made C: a data disk (not system disk). Of course, Windows doesn't support changing the drive letter for the system disk.
Video editing PC:
400GB video drive
