Hello, I haven't visited this forum for a while, it took a while to remember my login!
I've got VS7 which I find mostly adequate for what I use it for.
I'm planning on borrowing a capture card from a friend to capture analogue video from some old VHS tapes.
I've got a fair number of tapes that I'd like to capture before I hand the capture card back so I'd like to keep the disc space to a minimum. I don't want to sacrifice quality too much but being a VHS source I doubt it is worth capturing to 720 lines! Can somebody advise on the settings I should use?
I was surprised that I was unable to find the answer to this by searching the forum.
Kind regards,
Stewart
Capture settings from VHS
StewartTurner
http://www.deepset.co.uk
GuyL
- motherboard: ASUS P6T
- processor: I7 920
- ram: 6GB
- Video Card: ATI 5870
- sound_card: Auzentech X-fi Forte 7.1
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: LG W2753V & HP w2408h
Here is a great resource for this information:
http://www.digitalfaq.com/dvdguides/cap ... source.htm
Now using Adobe Premiere and Photoshop
Guy Lapierre
www.forefrontbusinesssolutions.com
Guy Lapierre
Borrow his/her capture software too. Analog capture almost always works better when the hardware and software are made to work together. Borrow your friend too!I'm planning on borrowing a capture card from a friend...
Once you have a digital video file, you can use VS7.
If you are making a DVD, the DVD's resolution will be 720x576 (for PAL video).I doubt it is worth capturing to 720 lines!
FYI - 720 is the horizontal resolution (columns). Vertical resolution is 576 horizontal scan "lines".
If DigitalFAQ.com doesn't answer all of your questions, another place you can learn about capture is VideoHelp.com
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
StewartTurner
To capture to Mpeg select DVD from the capture format.
I would first estimate the length of each Vhs tape.
To reduce the file size to below 4.3 Gb, I would change the Bitrate to match the length of movie using the options cogwheel.
Using Mpeg audio rather than Lpcm will also help.
As a Guide
You will fit 90 mins to a dvd at 6000kbps
You will fit 120 mins to a dvd at 4000kbps (very good quality Vhs)
You will fit 200 mins to a dvd at 2500kbps
Use a bit rate calculator to estimate this
http://dvd-hq.info/Calculator.html
As a guide read Bit Rates and File Sizes from the link below.
I just ran a test and changing to 352 x 576 frame size made little difference to the file size, which surprised me.
Once I have captured to the correct rate to fit a disc, I would keep the settings through-out the edit to burn a disc.
All the Best
Trevor
As a Guide
All the Best
Trevor
StewartTurner
Thanks again.
I should clarify that my reason for wanting to reduce the file size is not because I have a fixed length of film to fit to a DVD, more that I have multiple tapes to capture in one go and limited storage space.
I'm borrowing the capture device so I want to capture all my tapes at once before I start the painfully slow task of editing!
Stewart
Stewart
