Hi Masterworld
You cannot set the project properties as Vcd, as this is not a dvd compliant format.
I would use Avi as my project properties:-
NTSC drop frame (29.97 fps)
Microsoft AVI files
24 Bits, 720 x 480, 4:3, 29.97 fps
Lower Field First
DV Video Encoder -- type 2
PCM, 44.100 kHz, 16 Bit, Stereo
Edit the project.
Share Create Video File to same as 'Project Properties’
This will create a top quality video file to avi format.
(13Gb per hour)(its big)
Using this new file in a new project Render to Vcd
Share--Create Video File--Ntsc-vcd
MPEG files
24 Bits, 352 x 240, 29.97 fps
Frame-based
(Video CD-NTSC), 4:3
Video data rate: 1150 kbps
Audio data rate: 224 kbps
MPEG audio layer 2, 44.1 KHz, Stereo
This will create a VCD file of your movie.
Starting a new project you can use this file to burn a CD.
Alternatively you could skip the create Avi step and create a VCD from the project.
Although I think you will get better quality by creating an avi first (my personal preference)
Is this what you are looking for.
View the video on this site for movie examples created from Jpeg images only.
www.englishdvd.com
Trevor
