Photo and Video in one slideshow
ktykatkty
I just purchased PictureShow 4. Is there a way to put video clips within a photo slideshow? Thanks.
- michaeltee
- motherboard: HP 82F1
- processor: Intel Core I5 7400 3 GHz
- ram: 16 GB DC
- Video Card: Intel HD Graphics 630
- Hard_Drive_Capacity: 2TB Hybrid
- Monitor/Display Make & Model: Samsung S24D300
- Corel programs: Installed: PS Pro 2021, VS Ultimate 2020
Re: Photo and Video in one slideshow
Yes and no... there's no way to mix video clips and stills in a specific sequence (i.e.; alternating between video and stills in the same show) however you can select the "First Play Video" option on the "2 Theme" tab and have a video clip play BEFORE the slides. If you need more than one video clip you can use a 3rd party video "joiner" to combine multiple clips and then use the modified video file as your First Play. I haven't used the Firt Play Video feature in a while but if I recall correctly, the video clip will autoplay when the DVD is inserted in your player. At the conclusion, the slideshow menu appears and playback of your slideshow is initiated via the menu.ktykatkty wrote:I just purchased PictureShow 4. Is there a way to put video clips within a photo slideshow? Thanks.
-Mike
