MPEG files
24 bits, 720 x 480, 29.97 fps
Lower Field First
(DVD-NTSC), 4:3
Audio data rate: 256 kbps
Dolby Digital Audio, 48 KHz, 2/0(L, R)
The project settings for the DVD Authoring/Burner module are as follows, matching the video file:
MPEG files
Lower Field First
(DVD-NTSC), 4:3
I have made DVD movies of two different projects so far, and I have never checked or adjusted the "Disc Template Manager", by clicking the bottom leftmost icon in the burner module.
The default highlighted disc template during these two DVD burns was "HG 4:3 (Dolby Digital)" with the following properties:
MPEG files
Frame-based
(DVD-NTSC), 4:3
Video data rate: Variable (Max. 7000 kbps)
Please note the only two differences between the "disc template" settings and the "video file/DVD project" settings are the frame type (lower field first vs. frame based) and the video data rate (8000 kbps vs. 7000 kbps).
My question is this - when I burned my two DVD projects, what properties are on those two DVD discs - the 8000 kbps with lower field first or 7000 kbps with frame based?
Thanks for your help.
Bryan P.
Florida
