I've authored a bunch of DVDs shot in 4:3 NTSC and never had any complaints about how the picture looked on a widescreen TV (I don't have a widescreen TV to see how it looks). So apparently I've been using the "as is" setting for widescreen TVs without knowing it until I realized it was there. For these DVDs I'm doing now, there is musical information which needs to be able to be read (chord grids) by the user. Should I continue with the "as is" setting? Is there a way I can see what it will look like on a widescreen TV without having a widescreen TV?
Thanks again
output display options question
You should be OK. A widescreen TV will show the whole 4x3 image with black bars on the sides.
However, both formats have "overscan" Some of the picture is normally cut-off on all sides. The amount of overscan vaires with every TV, but it should not be more than 10%. So, don't put the chord grids at the edge of the image... keep them inside the "safe area".
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
dax702
