Error 5:0:0
LimpMan
Error 5:0:0
Post by LimpMan »
Please help me. when i try to burn dvd i got (error 5:0:0) in middle of progress............ any body have any idea.i'm using vs 10 plus.
Thanks in advance.
Rich2Putt
operating_system: Mac
processor: 2.9
ram: 8gb
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: IMac AIO
Re: Error 5:0:0
Post by Rich2Putt »
LimpMan wrote:Please help me. when i try to burn dvd i got (error 5:0:0) in middle of progress............ any body have any idea.i'm using vs 10 plus.
Thanks in advance.
LimpMan,
I got that message also last night "Unspecified Error' (5:0:0). After 3 hrs of trial & error, I found the glitch to cause this error (at least in my case). It was during the create disk process. I received this error message when it was 65% of converting menu files.
What I did was whet back to creating a menu & changed the background image. This did the trick. I was using "bonus" menu & choose the Beach scene (umbrella & chairs on beach).
What I would suggest to you is, render a 5 min video as a test, & go over the same steps. If it works with the menu's you choose, then it should work for the project your working on.
I took notes on this, but I am at work at the moment. Bottom Line: I change the background in the menu & it worked.
Let me know how you make out.....Rich
iMac AIO (late 2012)
Windows 7 (bootcamp)
VS Pro X3
8gb RAM
1 - 1TB HD
1 - 120 SSD
1 - 2TB External HD
Panasonic DVC-30
LimpMan
Re: Error 5:0:0
Post by LimpMan »
Thanks in advance.
LimpMan,
Thanks for your help....i'll try.
LimpMan
Post by LimpMan »
I still got same error message evean i change back ground.i try all the menu which came in vs 10.
Rich2Putt
processor: 2.9
ram: 8gb
Post by Rich2Putt »
LimpMan wrote:I still got same error message evean i change back ground.i try all the menu which came in vs 10.
The only other suggestion I have is insert your original VS10+ cd & try the "repair". See if that will work. Another thing I did was a system restore in windows xp-sp2.
Good Luck.......Rich
VS Pro X3
8gb RAM
1 - 1TB HD
1 - 120 SSD
1 - 2TB External HD
Panasonic DVC-30
alan.glaister
Post by alan.glaister »
You may also want to check your settings of the DVD burners IDE connection.
I kept having this trouble with VS9 when I got my new PC. They had set the IDE connection up with the default DMA, when I changed it to PIO Only - bingo worked every time since.
To check this goto Control Panel->System->Hardware->Device Manager
then expand IDE/SATA/ATAPI Controllers find your connection for your DVD burner then change it to PIO Only.
