problem with NVIDIA drivers
danardi
Post by danardi »
I've installed Ulead VideoStudio 10 evaluation in my Acer Aspire 1520 (GeForce Fx Go5700). In main editing windows I can't view preview images, but the small video preview is black! Images only appear when I stop reproduction..
I've verified this situation with all file formats, only exception is with non-compressed file (ie. DV).
To view preview in correct mode I must uninstall NVIDIA drivers..
there is a solution for use VideoStudio and NVIDIA driver?
there is any patch?
daniel
Post by daniel »
do you have all necessary drivers and codecs installed?
Ulead programs require and up to date Media player (MS) as well as the
Apple Quick Time and Realplayer software.
I can assure you I use(d) various Ulead softwares with nVidia cards (several) with old and new drivers and it always worked fine.
So it's a system issue in your machine.
danardi
Post by danardi »
I've not update these program. Which codec I must install and where I can find it?
Thank for support
daniel
Post by daniel »
http://www.ulead.co.uk/vs/trial.htm
you'll find links under the Instructions heading
danardi
Post by danardi »
it have not solved my problem.
The problem is in compatibility of videostudio with NVIDIA drivers. Codecs are ok because if I process from any format to any format, output file is correct.
