VideoStudio 8 Purchase
jmoon
Post by jmoon »
I am considering the purchase of this software. Are there any external devices I should consider buying? Either required or to make life easier while using the software.
Thanks,
John
dcampog
Post by dcampog »
It really depends on what you already have and what you want to do : if you have a digital camera which you can connect to your PC via the firewire and a DVD burner then you don't need anything else.
If you want to capture video from an analog source then you need a specific capture card. The same applies if you want to put on a DVD something that you captured from a TV programme, etc.
Maybe you should specify a little bit the aim of your question.
jmoon
Post by jmoon »
I have the CD burner and a very good digital camera. I would like to use some of my high 8 video also. Is there something special I would need for that?
joosuna
System_Drive: F
processor: intel dual core 3 Ghz
ram: 12Gb
Video Card: nvidia
Hard_Drive_Capacity: 2000
Post by joosuna »
jmoon, you mentioned you would like to use your high 8 video...assuming it is analog...you will need a capture card for the analog video. Also, if you are going to make a DVD, you will need a DVD burner.
