gif animator transparency
GIF Animator, SmartSaver Pro, Plugins, Applets....
racey
Post by racey »
I have just downloaded the free trial version of Gif Animator 5, and I have tried for a few hours now to create an AVI file with a transparent background but everything I have tried has failed, I have read the manual, my attribute toolbar seems to be different to the one in the manual as they have a transparent index option and I dont, any help would be much appreciated as it has me beat.
bryave
transparency
Post by bryave »
After creating the object, select the object using the Pick Tool. You'll find a Properties button that will appear at the top of the menu. Click the properties button and the Object Properties window will appear. Under the General Tab, you'll see a Transparency option which will now let you set the desired transparency percentage you like. Hope this helps. :D
†bryave
VikingAnimations
processor: AMD A4-6300 APU with Radeon HD Graphics 3-7 GHz
ram: 4 GB
Hard_Drive_Capacity: 1 TB
Corel programs: Ulead GIF Animator 5.05, MotionStudio 3D
Post by VikingAnimations »
Are you trying to save in AVI format? If so, the AVI format doesn't support transparent backgrounds. Only png and gif do.
