Photo Express Installation
mike
Post by mike »
Hello,
Has anyone had any installation problems with Photo Express 4.0 SE?
I've installed the program on a new PC (Windows 2000) and it installs fine but when I try to start the program by double-clicking onto the icon (or trying to initiate it through the application file) nothing happens. I've tried re-installing the software and the same thing happens ..... the software just doesn't start. Anyone had anything similar?
Thanks a ton in advance.
vwodwo22
I have the answer
Post by vwodwo22 »
I have been messing with this for a week but i finally figured it out......what you have to do is find the program on the computer
C:\Program Files\Ulead Systems\Ulead Photo Express 4.0\ipe40.exe
(sorry i cant give exact descriptions...i am using winxp, and i am not sure how much you know about computers)....anyhow....
1. right click on the program. (ipe40.exe)
2. click on properties
3. look for a tab that says "Compatibility"
4. where it says compadibilty mode, check the box and select "Windows 98/Windows Me"
5. Click accept
6. Run the program
ps. you may have to shut the program down first using "alt+control+del" before it will let you do it
:D hope it works
ajrfman
Post by ajrfman »
I cannot get it to work with Windows XP, either. What do I need to do?
Thanks.
ajrfman
Post by ajrfman »
After using the compatibility wizard with Windows XP, it worked after I chose Windows 95. ( I say "worked" because the program at least came on-I haven't used it yet.
Thanks for the information about compatibility.
I still get a "time out" when I try to register the serial number. Before, I reached a page saying that the serial number was already registered.
martynz
Post by martynz »
I'm having a problem opening it too. But I get a popup window called "Windows installer" and the message "Preparing to install.." but nothing happens. When I click on cancel again nothing happens and I have to go into Taskmanager and shut down IPE40.exe.
I'm going to try that earlier suggestion.
Martynz
martynz
Post by martynz »
I've tried the earlier suggestions but it still won't open. I've browsed back on this forum and it seems to be a recurring problem.
So I've uninstalled 4SE and reinstalled 3 which gives me no problems.
Martynz
