Long Time Now - Still NO PAL SUPPORT
crovie
Post by crovie »
No PAL support in MF5
There is a topic on it , posted a while ago
can't believe it has not resolved yet !
heinz-oz
Post by heinz-oz »
What are you talking about?
How did you install your version of MF5?
During the install, you have the possibility to select your TV standard as well as the country where you live. US american versions may be limited to NTSC, that I don't know, but that PAL is not supported :shock: what do you think people in europe, australia and the rest of the world, not using NTSC, are using?
Re: Long Time Now - Still NO PAL SUPPORT
crovie wrote:No PAL support in MF5
Crovie
This is the THIRD time this week I have answered your rant.
Step One
Step Two
heinz-oz
Post by heinz-oz »
:D Steve, I think we should stop feeding the troll Image
crovie
Sorry
Post by crovie »
Sorry I'll Keep the thread here only
Done What you've proposed - it has changed in there to PAL/SECAM
But still will not work - i think the problem is in -
Capture video (window) - Advanced settings... - video properties - input source (tag) - TV system menu is only showing NTSC and that's the only option it has !
Thank u
heinz-oz
Post by heinz-oz »
You didn't install correctly, try uninstall and fresh install with the correct settings.
crovie
No Good
Post by crovie »
Have tried that
Installed Again - with my country and PAL/Secam Selected !
Still Something simply not working ..
Begining to lose hope ...
GeorgeW
Re: No Good
Post by GeorgeW »
crovie wrote:Have tried that
Out of curiosity, what device are you using to capture? Sometimes if it is a capture device, you can check that company's support pages for software/driver updates.
What is the source material and hardware, and what connections are being made to your computer?
George
crovie
AverMedia EZMaker USB2.0
Post by crovie »
Using The component Connections.
It Worked Well in DMF 2 SE which came along the capture device
Will look for support there 2
crovie
And
Post by crovie »
And the source hardware is a vcr
old PAL tapes - on a PAL VCR
heinz-oz
Post by heinz-oz »
You might find that the software that came with your device is modified to work with that device. Use that to capture.
crovie
Dont Understand you
Post by crovie »
Sorry I dont Understand You
That's All the point - I wanna GO BEYOND dmf 2 se towards dmf 5 plus !
And Upgrade my software - which unfortunately i can't due the reasons above ...
Sorry i probably dont understand u ..
daniel
Post by daniel »
Heinz says: your hardware may only work with MF2.
So use MF2 for capture step, then process your video further with MF5.
heinz-oz
Re: Dont Understand you
Post by heinz-oz »
crovie wrote:Sorry I dont Understand You
I don't think it matters much what you want. If you try to run Windows XP on an old 386 PC, will that work just because you want to? Does a diesel car run on petrol just because you want to, no is the answer. Whether you understand that or not, is immaterial. These are the hard facts. Sorry.
I spell it for you once more: MF5 does support PAL and NTSC. It supports different capture devices too.
It just doesn't support your device.
I'm sure everyone else agrees, that this is hardly Uleads fault. It's the hardware manufacturers fault because they chose to stray from some neccessary standards.
Mostlikely it was cheaper for them that way but they supplied you a modified program which works with your device. What more do you want?
crovie
Funny
Post by crovie »
As Far as i understand my hardware is O.K
Pentium 4 ,2.6 GHz , 512 RAM - and the dmf5 does recognize the capture device - it works wonderful in NTSC mode - so why not in PAL ?
Especially When old versions support this feature (which implies that it's NOT a hardware issue at all) ! if an OLDER version of the product support PAL - There is no reason what so ever that the NEW version won't support it - it's not like PAL method is fading out from this world
As for your metaphor - I bought the car in Japan why it would not drive in Italy ???
And As for Ulead's Fault -you said "they supplied you a modified program which works with your device... - Ulead Is A Part of - they .
p.s.
I have downloaded other versions & Softwares from Uleads Site - that works great with my device - including Video Studio 10 plus (DEMO VERSION) !
How Can u explain that ?
