I don't believe we have enough information to rule out bitrate. Consider the OP said this:
Wow, VBR encode with 8000kbps plus 1536kbps audio = 9,536kbps (Video + Audio). Some machines will have a problem with that on home made dvd's (others might not). Now throw in the potential for VBR bitrate spikes, and your bitrate can all of a sudden jump over 10,000kbps (yikes).Hi the rate is variable up to 8000 kbps and the audio is LPCM. I am going to give it a try dropping the rate to 6000 and speed to 4x. Do you reckon this will do the trick?
But we do not know exactly what the OP means by "only plays on some dvd players" (which is why I asked for clarification).
It might turn out to be a burner/disc issue as you say, it might be a bitrate issue as well - or a combination of both, plus how the stars are aligned today
George
