VS7 sending video to camcorder problem
Chewie
Post by Chewie »
I have a finished AVI file that I need to send back to my camera.
I click on share/ export/ DV recording, and the DV recording box comes up.
I then click "next", and I get an error message saying it doesn't recognize the camera.
What am I missing?
I tested my camera by receiving signals from my vcr, so it's not the camera.
Post by BrianCee »
You presumably tested your camera by connecting it to your VCR via the composite (red, white, yellow leads) - but when you want to send your movie from your PC to your camera you need to use the firewire connection (aka i-link, IEEE1394, DV port etc.) do you know if your camcorder is enabled for DV-in (NOT AV-in which you used with your VCR) and are you connecting via firewire.
Chewie
Post by Chewie »
Thanks Brain,
At least now I know where to focus, because I tried every possible cable connection.
I do have a DV in with a USB on the other end, but to no result. Maybe it's a bad cable.
My camera is a Canon Z45.
Post by BrianCee »
Sorry - what do you mean "DV in with USB on the other end" - DV means firewire - NOT anything to do with USB - you need a firewire cable connecting the firewire (DV) connector on your camera to a Firewire port on your PC
Chewie
Post by Chewie »
Sorry, I must've misread the cable connector names. The camera does have a DV port, but that is not the cable I have.
And since I don't have firewire cables, that would explain why it doesn't work.
Thanks Brian.
Chewie
Post by Chewie »
I had to get a firewire card & cable, and now it works.
Thank you very much for the help, Brian!
I really appreciate it.
