Semi-Transparent Model Imports
BillRobert
Post by BillRobert »
Been a big fan of this software for years, but I do have one recurring problem which is kind of driving me nuts.
I cannot get .3Ds (3D Studio Max) models to import properly, The shape is there OK, but I am getting this weird semi-transparent thing going on in the model itself. I have even tried converting these models to DirectX models and am having the same trouble.
I've tried WinConv, Deep Exploration, even 3DSMax itsels, to no avail?
Am I missing something, or am I just stuck?
Many thanks to one and all who reply....
rwernyei
Post by rwernyei »
Bill,
I use both .x and .3ds models all the time with COOL3D PS. Upon importing the models you have two choices: C3D and D3D. C3D will import with no texture, D3D will. Also another consideration is that the .3ds was not created and packaged correctly. By using a program like Deep Exploration, one can unpackage the model including its texture. This would help determine if the texture is actually the problem. Other areas: Were these downloadable models or created by yourself. Are you all caught up on your Direct X and graphics card drivers? Also a sample pic would help.
BillRobert
This part I've got down. I've been generating models in Cool 3D for a while, and when I do the .d3d option I get a textured semi-transparent thing. When I import the .c3d I get a beige, semi-transparent object.
As far as I know my drivers are fine, as well as my Direct X Version.
99% of the models I have been using have been made in an app called Ldraw and from there have been converted to .3Ds files. I downloaded one to try it out, and it is problematic as well.
[/img]
rwernyei
Post by rwernyei »
Bill,
One possibility is when converting your Ldraw model to .3ds something is getting lost in the conversion process which is resulting in a failed import in COOL3D. Have you tried simply downloading a .3ds model from the web and importing it into COOL3D with .D3D option?
Here's a site with tons of free .3ds models.
http://www.amazing3d.com/free/free.shtml
Give it a go and see if you were able to correctly import the model with all its attributes, texture, etc... If you were successful, by process of elimination, I would deduce that it is this conversion step from the Ldraw app to .3ds that is giving you the trouble.
Hope this helps.
