Missing some stuff after upgrading from 8 to 10
dsegarra
Post by dsegarra »
Hi all, I just upgraded from VS8 to VS10 and I have four questions:
1- How do I get all my VS8 DVD menus into VS10, my upgrade only came with three templates and that is very dissapointing.
2- Also my help file is missing so I cant get help through the program
3- The DVD menu customization process is much more confusing than in VS8. VS8 was very intuitive, VS 10 I'm having problems figuring out how to customize (change text colors, etc especialy without the help file) is ther a tutorial using VS 10 online somewhere?
4- Lastly VS 10 crashes after I quit then I can't start it up again without rebooting the PC is there a fix for this?
Vers:10.0.0110.0 Plus
Post by Trevor Andrew »
1 / If you only have three templates, have you installed VS 10 correctly.
I see 10 when I select ‘All’
Have you installed the Indeo and QT drivers.
This is only a work-round. It should work, but I do not have VS 8 installed to test.
read http://phpbb.ulead.com.tw/EN/viewtopic.php?t=16399
copy your Ufo files from VS 8 to 10
2 / The help files can be accessed via F1, if you cannot see, then I would assume VS 10 is NOT installed correctly.
3 / To customise your menu select the ‘Edit’ tab at the top.
Click the text on preview screen—Then Font settings.
The menus in VS10 are a little different to VS 8 as you have three types of template.
Choose Thumbnails from the dropdown box for similar types to VS 8.
Hope this Helps
Trevor
Did you install the extra content?
See also:
Authoring a DVD
Sharing menus and transitions etc between products
dsegarra
Video studio
Post by dsegarra »
Thanks guys, I downloaded the extra content, then it would not work. I reinstalled VS10 upgrade then the content again and wala, it's working fine now. Now I have all my missing stuff. It must have been a bad initial install.
Thanks for the help.
