movie factory 3 file format not supported
thunder007
My capture was file in mpg will not write in dvd factory ,get errors can not open file & file format not supported
heinz-oz
thunder007
movie factory 3.0
I captured with dvd xpress from analog camcorder to convert to mpeg2 but the file says mpg .I tried copy to disc with move factory 3 thats were I had error ,source file had some problems ,then file format is not supported,I have done all the update for factory 3 se
Copied from your other similar post, which I deleted:
Your MPEG file is probably corrupt. Maybe you had a "glitch" during capture. The Ulead programs sometimes have trouble with MPEGs, especially if they are corrupted. It can be hard to tell, because a corrupt MPEG will sometimes play OK.
Did you capure with Movie Factory, or with the special capture software that's made for your hardware? (CapWiz?) You are usually better-off using the software that's designed for your hardware.
No. I don't think you get support with the "free" SE versions.thunder007 wrote:I have error dvd folder is not supported,this is the folder I captured to so why is it not supported ,and how do I make a dvd supported folder,Is there any support for this software
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
- ram: 2 GB
- sound_card: Intel GMA 950
Please view
MF4: Create DVD from Hauppauge TV Card
Treat this article as an example of how to use MPG files created with an external program. The precedure with Version 3 shouldn't differ much from version 4.
