Audio volume control not working
wipi
I can't get around the following problem in VS 10:
Whenever I adjust the "rubber band" control (the red line) in an audio clip, it has absolutely no effect on the volume played. The overall volume control (the green line) however works fine.
I've tried this on several different projects and audio files - no change.
Any ideas how this can be resolved?
Thanks for feedback, regards
Willy
Willy
GuyL
- motherboard: ASUS P6T
- processor: I7 920
- ram: 6GB
- Video Card: ATI 5870
- sound_card: Auzentech X-fi Forte 7.1
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: LG W2753V & HP w2408h
wipi
GuyL
- processor: I7 920
- ram: 6GB
To select ‘Project Playback’
Do one of the following
Click the word ‘Project’ adjacent to the ‘Play Button’
The word Project will change to a blue colour indicating project playback.
Click the White Time Rule at the top of the timelines. This will position the curser, this position is where the Project playback will start.
In project playback all timelines are played together.
In clip playback the individual clip/title/transitions etc are played on there own.
Trevor
Trevor
GuyL
- processor: I7 920
- ram: 6GB
wipi
Guy, Trevor,
thanks a lot for the advice. I notice in fact that there is a difference between clip play and project play, but also "project playback" to screen.
The latter option works fine (regarding the audio volume control), but you have to run the whole project, so it's not suitable for quick check of a sequence.
Project play preview renders sound control correctly. However, the thing that threw me off is that an FX transition overruns the sound control (e.g. a lead-in); that is not the case when you do a project playback.
And finally, as you indicate, clip play preview disregards audio control all together.
Sounds complicated? It is and I am not sure it all works as designed.
Regards
Regards
GuyL
- processor: I7 920
- ram: 6GB
You can play back any portion of the project. After you click "project" drag the trim handles to the start and end points you wish to preview and hold down shift when you click play. It will play only that section. If you want better quality previews then change the preferences to quality playback from instant playback. The file will be rendered before the preview is played.wipi wrote:Guy, Trevor,
Regards
Now using Adobe Premiere and Photoshop
Guy Lapierre
www.forefrontbusinesssolutions.com
Guy Lapierre
is@northcentralems.com
Same Problem
I have the same issue, with the audio not changing when I rubber band it. Althought after reading this forum I have realized that I must use the project playback - however I did notice that when I want to fade out something, I lower the rubber band all the way to the bottom, but it does not completely shut off the sound, so I still hear some sound, thereby it doesn't fade out perfect all the way. I would say it fades out down to 20% or maybe even 10% but then you notice an abrupt stop at the end of the clip.
blplhp
- motherboard: Dell Motherboard
- processor: AMD Phenom II 6-Core 1055T
- ram: 6GB
- Video Card: ATI Radeon HD5670
- sound_card: Soundblaster
- Hard_Drive_Capacity: 1TB
wipi,
I have your solution for a quick preview of the video clip's audio adjustments without having to preview the whole project in Project Mode. This will work as long as the trial version has the control panel tab explained below.
Click on the Audio View button just above the timeline ruler. This displays the waveforms and the rubberbands of your video/audio clips. Click on a video or audio clip in your timeline to highlight it. Next, click on the Surround Sound Mixer tab in the Control Panel section of the program window. Do you see the blue Play button to the top left of the speaker location diagram? Click on this Play button and you can preview your rubber banding edits without having to go to Project mode. Click on the next clip to highlight it and then click on the Play button again to preview your audio edits.
Works every time for me.
Cheers,
Bryan P.
X2 Pro
X3 Pro
Adobe Elements 8
Sony DCR-TRV315 Camcorder
Canon G10
Canon 40D
Bryan P.
X2 Pro
X3 Pro
Adobe Elements 8
Canon G10
Canon 40D
Re: Same Problem
I have found if I have, say, a 2 second fade out then, yes, it seems to end rather abruptly rather than fading. But if I change it to a 4 second fade it sounds much better.is@northcentralems.com wrote:I have the same issue, with the audio not changing when I rubber band it. Althought after reading this forum I have realized that I must use the project playback - however I did notice that when I want to fade out something, I lower the rubber band all the way to the bottom, but it does not completely shut off the sound, so I still hear some sound, thereby it doesn't fade out perfect all the way. I would say it fades out down to 20% or maybe even 10% but then you notice an abrupt stop at the end of the clip.
Jeff
Dentler's Dog Training, LLC
Re: Same Problem
Hiis@northcentralems.com wrote:I have the same issue, with the audio not changing when I rubber band it. Althought after reading this forum I have realized that I must use the project playback - however I did notice that when I want to fade out something, I lower the rubber band all the way to the bottom, but it does not completely shut off the sound, so I still hear some sound, thereby it doesn't fade out perfect all the way. I would say it fades out down to 20% or maybe even 10% but then you notice an abrupt stop at the end of the clip.
I find it difficult to select the last frame using the rubber band, especially when the trim handles are in the way.
You could expand the timeline to view a single frame, Although I use the Fade in--Fade out buttons instead of the rubber banding.
This should fade to the last frame.
Set the default time in file preferences.
Or drag the start fade point to adjust.
Trevor
That does the same thing as clicking Project Mode then Play. Using your way is one less click but I have to move my mouse farther.blplhp wrote:wipi,
Jeff
Re: Same Problem
Something else you can try. In Audio View, move the cursor to the very end of the audio clip that you want to fade out (with your clip selected click the End button located under Trim Handles). On the Attribute tab, with your clip selected, click on the Fade Out button. Now, on the Surround Sound Mixer tab you will see 3 sliding scales. The one on the left is for the volume. Slide that all the way down. That will ensure there is no volume at the end of the clip. As I stated previously, adjusting the length of the fade also improves it, IMHO.is@northcentralems.com wrote:I have the same issue, with the audio not changing when I rubber band it. Althought after reading this forum I have realized that I must use the project playback - however I did notice that when I want to fade out something, I lower the rubber band all the way to the bottom, but it does not completely shut off the sound, so I still hear some sound, thereby it doesn't fade out perfect all the way. I would say it fades out down to 20% or maybe even 10% but then you notice an abrupt stop at the end of the clip.
Jeff
