I would like to first get files off of a DVD (which I learned how to do from this forum- thanks) and then edit the MPEGs. Is it going to be a problem to edit the MPEGs? I've read on here that they ARE editable and it is a good idea to turn smart render off, but I've also read that people much prefer editing AVI and DV files. What is the difference as far as editing? What problems may I run into when editing MPEGs? Thanks
Dann
Editing Mpegs from a DVD
stannmaple
- ram: 2 GB
- sound_card: Intel GMA 950
Whilst you CAN edit MPEG files you must bear in mind that many users experience audio/video synch issues. From my experience these issues are mostly aggravated when inserting transitions between clips.
Please view:
Audio/Video Synchronisation Issues
Please view:
stannmaple
Hi Dann,
You're mixing different things in your message.
MPEG files ARE editable, yes, and most people prefer using AVI files than MPEG for editing. And some say to avoid Smart render.
Separately you're right on all three.
B U T : if you have MPEG to start with, as in your case, by all means do use smart render to avoid recoding untouched parts.
Don't certainly go back to AVI, use AVI if you can FROM THE START.
You have MPEG now, go with MPEG, just make sure you usi the same properties in the whole chain from editiing to authoring (field order, data rate).
Daniel
This is my opinion. Your mileage may vary.
No warranty implied. Not a scientifically proven fact.
Some may disagree. Use at your own risk.
Don't let children play with it. I never said that.
Daniel
jchunter
Stannmaple,
It would be counterproductive, to say the least, to transcode DVD-compliant mpeg2 to DV, edit DV, and transcode back to Mpeg2 to burn on DVD because each transcoding will reduce picture quality, not to mention wasting your time and increasing your chances of an operational mistake.
Your best workflow is to edit the mpeg2, using virtual cutting tools such as the scissors and Multi-Trim Video and Smart-Render the output video file. Then burn the DVD after setting the BURN properties to match the video file properties.
Mpeg2 is very editable. Mpeg does not cause audio/video sync problems. Your foot will not fall off if you edit mpeg2.
Joe Louvar
Re: Editing Mpegs from a DVD
None, I edit my Sony DCR-DVD405 DVD camcorder MPEG-2 clips in VideoStudio 10 Plus without any problems.stannmaple wrote:I would like to first get files off of a DVD (which I learned how to do from this forum- thanks) and then edit the MPEGs. Is it going to be a problem to edit the MPEGs? I've read on here that they ARE editable and it is a good idea to turn smart render off, but I've also read that people much prefer editing AVI and DV files. What is the difference as far as editing? What problems may I run into when editing MPEGs? Thanks
Dann
stannmaple
