GIF Animation image size
I am trying the trial version of this software. Using the animation wizard, is there anyway to set a default to use the image size? As I can see it, it has a bunch of presets and you can type in a size. I would like something that automatically detects the size and uses it. Thanks
- VikingAnimations
- processor: AMD A4-6300 APU with Radeon HD Graphics 3-7 GHz
- ram: 4 GB
- Hard_Drive_Capacity: 1 TB
- Corel programs: Ulead GIF Animator 5.05, MotionStudio 3D
The easiest is to not use the Wizard. Just use "open" to open the image that will be the first frame of your animation. Then use the "Add Image" button to add the remaining parts of your animation.
The other handy alternative, if you want to use the Animation Wizard...
Once you've added all the images, select Frame 1. Then go to the Object Manager. Then select the image that is visible in Frame 1. Then click Edit, "Crop canvas." That'll do it, too.
Last edited by VikingAnimations on Thu Oct 05, 2006 12:07 pm, edited 1 time in total.
