damaged ufo file :(
gr33r
damaged ufo file :(
Post by gr33r »
I have PI10 ... and after I save my file, now I can't open it ... I get the following message : Unable to open file c:\xxx.ufo [800:93:4525]
Can anybody tell me if my file is damaged and how to open it? how to fix it?
thanks.
MaryLouW
Post by MaryLouW »
I would suggest that you contact Ulead by filling out a help ticket. or if you're in the United States, give them a calll at their toll-free number:
Support
http://www.ulead.com/tech/suppform.htm
Call 1 (310) 896-6391, Monday-Friday, 8:30am-5:00pm PST
or 1-800-539-0466
[url=http://pircnet.com/]PhotoImpact Resource Center[/url]
[url=http://wwell.net/]Wishing Well Tutorials[/url]
[url=http://pircnet.com/forum]PIRC Forum[/url]
roa3
Post by roa3 »
yeah...
i've similar problem...
So now i'll have a lot of back up files!!!
heinz-oz
Post by heinz-oz »
roa3 wrote:yeah...
Why don't you open the last back up file? At least you should have something to recover from without redoing the lot :wink:
This problem has been known to happen with the system doing regular automatic save actions or if some background task is taking too much in resources at a crucial time.
I would check my preferences and disable the auto save function (don't forget to save manually every now and then), make sure I have plenty of free space on the drive or partition where I keep my Temp files and disable the option to let PI check for updates regularly.
Active internet connections, especially where certain programs constantly check for updates, instant messenger programs, file sharing and the like are other possible culprits.
heinz-oz
Re: damaged ufo file :(
Post by heinz-oz »
gr33r wrote:I have PI10 ... and after I save my file, now I can't open it ... I get the following message : Unable to open file c:\xxx.ufo [800:93:4525]
thanks.
The file is corrupted and there are many reasons why this could happen. Just refer to the post above.
Do you have a backup copy of your file? Some times it also helps to rename the file in WinExplorer and open it again with PI.
Other than that, I fear, you may have to start over :?
roa3
Post by roa3 »
U're correct heinz-oz, we should off the auto-save...
but the problem is PI uses a lot of computer memory, u can check in Task Manager, Iedit.exe...
too bad
heinz-oz
Post by heinz-oz »
Be that as it may, I certainly do not have the problems refered to here. If you want to work with large images, you'll need some memory to do it with. If you have a better solution, let's hear about it :wink:
roa3
Post by roa3 »
My suggest is:
If we want to open a large images, open in Paint program installed in our Windows XP one?? (click windows, roll over all programs, roll over accessories then Paint, Paint is my first design software hahaha...)
I mean, open in paint then crop the size, then open again in ulead photoimpact...will it be better?? I havent tried yet.
Anyway...save your files manually n often is very important, really!!
heinz-oz
Post by heinz-oz »
roa3 wrote::?
My suggest is:
I'm not quite sure if I understand you right. Opening an image in the Win paint program is certainly not an option for me. I work with large images and want them to stay that way :roll:
PI does offer the possibility to open an image only partially though. Have not had to use it much because my system is amply spec'd. Did it once as an exercise in the beginners work shop offered by the PIRC group here http://www.pircnet.com/.
It may be a good idea for you also to take this work shop. It gave me a whole new outlook on things and will certainly give you a very good understanding of all the PI tools. The PIRCNET web site also has a lot of links to useful and interesting tutorials as well. Certainly worth a visit.
roa3
Post by roa3 »
Wow...
Will definitely go there n take a look
