CAPTURE PROBLEMS VS10+
dcailler
Post by dcailler »
Having problems getting a good capture...both the sound and the picture have problems...skipping sound..choppy picture...never had a problem before...checked my settings they are ok...I checked the directions in the forum ...I've used VS9 before and never had this problem...so I tried capturing using my old VS9 and it was a litlle better...but not much better...please help...I'm doing a wedding tomorrow and I need my software to work...
Thanks in advance....
Dcailler
Dcailler,
I really don't know at this point, how are you capturing your video, and what settings are you using?
dcailler
Post by dcailler »
Trying to capture Microsoft AVI
24 Bit 720X480
4:# 29.97
DV VIDEO TYPE 1
DV Audio 32,000 12bit stereo
tried to set audio higher but it doesn't seem to stay at 48,000 16 bit
hope this is all the information you need...this is the first time I've had trouble capturing...
Everything looks good there, however are you capturing Lower Field First? Then are your project settings matching? Given what you have provided I'm leaning more towards a Field Order issue. If you have reversed your field order then you would get some of the problems you are experiencing.
Unless your video is recorded by your camcorder in 16bit then VS will capture it to 12bit.
dcailler
Post by dcailler »
I am using lower field first....
dcailler
Video Studio capture problems
Post by dcailler »
When I changed the capture file setting from avi to mpeg it seems to be capturing correctly...I still would like to know why I can't capture with avi anymore...very strange....but at least if I capture with MPEG2 I'll be able to work on the wedding video I'm taping today...will capturing in mpeg cause any problems in the editing phase...or DVD burning later?
My processor is only 2.4g but my video memory is 256meg...just put in a new video card EVGA 6800 and I'm using 2 monitors...that wouldn't have anything to do with my problems would it?
Thanks for all your help so far!
dcailler
What capture driver/plug in are you using, Ulead DirectShow Plug-in? For DV capture you should use that one.
I have a suggestion, try capturing using the free program WinDV, you can get here: http://windv.mourek.cz/. Some members including myself use it. You can capture DV-AV with firewire. It's a lightweight program that does a great job of capturing. See if you get the same problems.
You can edit MPEG-2, however members have reported problems when doing so. It is very crucial that your video and project properties match. This would alleviate re-encoding, which of course can lead to degradation and sync problems. Also make sure that Smart Render and Perform Non-square Pixel Rendering are not checked, if you are going to edit MPEG-2.
dcailler
Video 10 capture problems
Post by dcailler »
I dowloaded WINDV...how exactly do I use this program...doesn't seem to be working for me...I tried capturing using Windows moviemaker it did ok...but when i loaded the video file into VS10 it went in as one big file can't break it into samll clips to do editing ...also started having the same problems towards the end of the capture file...this is very frustrating to say the least...have used VS software before and successfully completed four big projects with out all these problems capturing...thanks for your help...sorry to be such a pain...
Dcailler
WinDV is really too easy, there's nothing in depth or fancy about the program. It does one thing and that is capture or actually transfers video data from the camcorder via firewire to your computer.
To use it simply go to the website (link provided above). Where you see the Screenshot mouse over it. You can click on the tabs, and also tool tips will pop up telling you about each control. The Discontinuity Threshold is similar to split by scene.
Were you able to capture anything at all with WinDV?
dcailler
Post by dcailler »
Yes I was able to capture with it, but when I play it back the video clip speeds up at the end of the clip.
I've never experienced a capture speeding up. You mentioned that you are using 2 monitors, and a new card. Have you checked to see if the drivers are up to date for the video card? Sometimes even though the card is new to you, there may have been updates issued in the meantime.
Also are you showing any drop-frames? Are you running any background apps? When capturing are you able to control your camcorder from within WinDV, VS or WMM? Capturing is done in real time so the camcorder would have to speed up, like clicking the fast-forward, unless this speed-up only happens to the clip after it has been captured, and not during.
tommytucker
Capture issues
Post by tommytucker »
I wish I could capture faithfully using VS10+, but I keep seeing frames dropped in the counter window. However, using WINDV, I never see even one frame dropped in WINDV counter dropped frames window. If there are any settings that could be optimized for capture in VS, I would love to hear about them so that I could keep everything under one roof so to speak.
maddrummer3301
Post by maddrummer3301 »
