Hi there everyone on this forum, I have been reading through lots of your posts on here and there seems to be a great deal of experianced users on here. So may be someone could answer my question.
SUBJECT: Error Message in Video Studio 10 Plus
Full CD Boxed Version
Nature of the problem : Getting and error code randomly when I am using the software after doing various things.
Properties of your source files : MPG2 files from Sony HDD camcorder. PAL
Error Codes is as follows:
Red X in a Circle POPUP
The instruction at "0x00000000" referenced memory at "0x00000000".
The memory could not be "read"
Click ok to terminate the program.
OK
System information:
Alienware Area 51 PC
Intel D875PBZ MOTERBOARD
Intel Pentium 4 3.00GHz
2Gb of DDR PC3200 Ram
ATI Radion 9600 XT 128Mb
Windows XP
Thank You In Advance.
Memory Error Message in Video Studio 10 Plus
If indeed the addresses in the error message are all zeros, then I would be very suspicious about one of my RAM sticks being defective. That sort of message can either indicate that there is a conflict with another program trying to acess the same RAM address at the same time as VS; OR it can indicate that the address simply can't be accessed by the program because it is defective. And if the address is absolute zero, this tends to imply (at least to me!) that VS simply can't address the RAM stick at all.
Do a Google search for a free RAM test program. Microsoft has a free one, though I don't have the URL for it, I am sorry...
Otherwise, as a work around, you would have to remove one stick of RAM, and run VS for a while and see if the problem recurs. If it does not, you could remove that stick and replace it with the other one. If the problem recurs with that stick, then that would appear to be your culprit. The good news is that RAM is pretty cheap these days.
