Importing Previous Projects to edit in a New Project
krwzmann
Post by krwzmann »
Hi All. Most of my event videos have been 'long form'. 5 Chapters (5 seperate projects) each anywhere from 5mins to 1 hour in length each. I've decided to try doing 'short form' projects where I combine the best scenes/sequences from the 5 chapters into the one project. Rather than go back to the original video files from Camera 1 / Camera 2 / Camera 3... I found it much easier to just insert the project chapters into my short form project and then trim and edit those inserted projects as needed.
The concept seemed great and I thought it looked good until I discovered that there is severe interlacing on the rendered video. I thought I tried all of the different options (upper field / lower field / etc) but the interlacing always shows up.
As a test... I went back to one of the chapter files and rendered it and it looked fine. I then opened up a new file....inserted that recently tested chapter file...and rendered out a video file with all of the same options and the video was interlaced.
Anyone have any feedback or ideas on how I can fix this? I spent a good amount of time making that 'short form' project but now it looks like I might not even deliver it on the client's disc because the interlacing is unbearable.
Thanks for any help!
Footage is 1080i smart proxy to 720x480 video
To be created and viewed as a DVD
If you need more info for anyone that can help...please let me know.
