Plug-ins Cool 3D 3.5
girly
Post by girly »
Some of the plug-ins are missing from this version ie Motion Path & Motion Blur, there may be others but not checked. Do these come as standard or do they have to be bought separately.
Also a lot of the thumbnails are not included with 3.5 and the older version was uninstalled so I have lost them.
If I run version 3.0 on top of the new version will it work just so I can copy the thumbnails.
tommytucker
importing from 3.0 to 3.5
Post by tommytucker »
I had to do that also and I was able to import those presets from 3.0 into 3.5. You can also download those presets and help files for 3.5 from here
http://www.ulead.com/tech/c3d/c3d_ftp.htm
girly
Post by girly »
Thanks.
Another question, how do I import the thumbnails into 3.5 I have installed version 3 again. I particularly would like the roundabout with 2 horses in the studio composition set. In 3.5 there are only about 6 pictures.
klowther
Post by klowther »
In version 3.0, right click on the composition that you want and select export from the context menu. This will give you a dialog box where you can specify the name of the .uez file that will be created.
In version 3.5, right click in the easypalette and select import from the context menu. Specify the name of the .uez file you created in version 3.0.
Hope that helps.
- Ken
girly
Post by girly »
Thanks again I'll give it a go.
