Error 80041c21 sur ulead video 8
furet77
Bonjour
Voila je possede ulead video 8 ..mais j'ai un petit soucis lorsque je veux compiler ma video en dvd j'ai un message d erreur qui apparait '' error 80041c21 ''
j'ai donc désisntaller ulead video 8 et apres impeccable cela a marcher mais j'ai essaye un nouveau fichier et j'ai eu de nouveau le message d'erreur comme ci-dessus j'ai essaye de desinstaller et reinstaller mais la toujours ce message d'erreur
si quelqu'un pouvait me venir en aide
désolé je passe passe par un traducteur donc si quelqu'un peux m'aider en francais cela serait beaucoup mieux
Merci pour votre aide
Hello
Veiled I @@possede @@ulead @@video 8 ..mais I have a small concerns when I want to compile my @@video in @@dvd I have a message d error that @@apparait @@'' @@error 80041c21 @@''
I have therefore @@désisntaller @@ulead @@video 8 and pungent impeccable that has walked but I have tried a new file and I have had new the message of error as above I have tried @@desinstaller and @@reinstaller but the always this message of error
if someone could come me in assistance
sorry I pass pass by a translator therefore if someone can help me in @@francais that would be a lot better
Thank you for your assistance
Hello
The only thing I really understand about your posting is the error code. Error 80041c21 is usually associated with file conversion and insufficient space on a Disk. I think you may be trying to burn an avi file direct to DVD. Because avi files are large in size, they need
to be compressed to a format that would allow the data to fit
onto a recordable DVD. Convert your .AVI files to MPEG2 files and then burn to DVD.
Terry
furet77
Thank you for your reponse
I engrave with nero and I desirerais to know what models to choose to engrave file ++Mpeg2 because nero proposes some several and and I do not arrive has read the file entiierement on my reader ++DVD that cuts several @@scenes during the perusal on my reader ++DVD
Thank you
Thank you
Comme TDK a déjà dit, je crois que tu essayes de graver un fichier .avi directement en DVD, mais sans avoir produit tout d’abord un fichier converti en mpeg-2. En plus, ton fichier .avi a été produit avec un codec comme Xvid ou 3ivx ou même DivX qui ne sont pas pour quelque raison compatible avec Video Studio. Et il me faut ajouter ici que VS8 n’était pas compatible avec des fichiers mpeg-4 généralement, y inclus les codecs comme DivX. Est-ce que tu peux confirmer les spécifications de tes fichiers ? Mais comme TDK, je te conseille de tout d’abord les convertir en mpeg-2 utilisant un programme comme TMPGenc ou DivX Converter ou même SUPER qui est gratuit.
Et les propriétés du fichier mpeg-2 doivent comprendre les suivants:
MPEG files
24 bits, 720 x 576, 25 fps
Lower Field First
(DVD-PAL), 4:3 (ou 16:9 si les fichiers sont tels)
Video data rate: Variable (Max. 8000 kbps si tu veux une qualité la plus haute – cela produit un DVD d’une heure; 6000 kbps pour une DVD de 90 minutes et de bonne qualité; et 4000 kbps pour 2 heures et une qualité raisonnable).
Quant au format audio, tu peux choisir ou LPCM (qui te donnera une haute qualité mais un fichier audio très grand) ou Dolby ou mpeg layer 2 qui sont de très bonne qualité et beaucoup plus petits que les fichiers LPCM.
For the information of others, the essence of what I said is that TDK1044 is correct. That message is related to a file conversion error. More specifically, though, it relates to an AVI file produced with some specific CODEC like XviD or 3ivX which contain some corruption or are not immediately compatible with Video Studio. VS8 was not of course compatible with any flavour of mpeg-4. Our advice in the past has been to use some other converting tool like TMPGEnc, the DivX converter or the free program SUPER to convert the AVI to MPEG2. I then went on to suggest what the properties of the mpeg-2 files should include.
And for the sake of completeness, the original message reads: "Well, I have VS8. But I have a concern. When I go to compile my video on to a DVD, I get an error message 'error 80041c21'. I therefore uninstalled VS8 which went without a hitch, but when I tried a new file I received the above error message again. I tried uninstalling and reinstalling but always get this error message. Hoping someone can help me. Sorry but I have to use a translation program. So if someone can help me in French, it would be much better."
And the second message, though in 'English', I think should read "I burn with Nero and I would like to know which format I should choose to burn an mpeg-2 file because Nero suggests several and I can't manage to get the file completely read on my DVD reader which cuts off several scenes."
MPEG files
Lower Field First
furet77
Merci tout d abord a TERRY et TDK pour votre aide
Pour reponse a ta reponse BERRY je n'essaie pas de graver directement mon fichier AVI mais simplement de le convertir en fichier ISO afin que je puisse le graver avec Nero ce qui me donne generalement un dossier DVD soit fichier audiots et fichier videots. Mais suite a la réponse de TDK je crois que mon probleme vienne du manque de place sur mon DD .
De plus j'ai converti mon fichier AVI en mpeg2 mais lorsque je le grave mon lecteur de salon ne lit que le tiers du fichier ( qui fait 3 go environ )
Donc je ne sais quel modele prendre avec Nero..
Voila
En tout cas merci a tous deux pour vos reponses.
Thank you all d approach has ++TERRY and ++TDK for your assistance
For @@reponse has your @@reponse ++BERRY I do not try to engrave directly my file ++AVI but simply to convert it in file ++ISO in order that I could engrave it with ++Nero what gives me @@generalement a file ++DVD is file @@audiots and file @@videots. But continuation has the reply of ++TDK I believe that my @@probleme comes from the lack of place on my ++DD .
More I have converted my file ++AVI in mpeg2 but when I the serious my reader of lounge read only the third of the file ( that makes 3 @@go approximately )
Therefore I not to know what models take with ++Nero..
Veiled
In any case thank you has all two for your @@reponses.
Voila
Veiled
Translation: "First of all, thanks to Terry and TDK for your help.
"As a reply to your reply, Berry, I am not trying to burn my AVI file directly but simply to convert it to an ISO file so that I can burn it with Nero, which generally gives me a DVD folder, be it Audio_TS or Video_TS. But following TDK's reply, I think my problem flows from lack of space on my hard disk.
"Moreover, I have converted my AVI file to mpeg-2 but when burned, my stand-alone DVD player only reads a third of the file (which is about 3GB). So I don't know what template to use with Nero.
"Well, there it is. Anyway, thanks to both of you for your replies."
Furet77 – je t’ai déjà donné les spécifications que tu peux utiliser pour t’assurer que ton vidéo corresponde à la place disponible sur un DVD de 4,7go : « (Max. 8000 kbps si tu veux une qualité la plus haute – cela produit un DVD d’une heure; 6000 kbps pour une DVD de 90 minutes et de bonne qualité; et 4000 kbps pour 2 heures et une qualité raisonnable). » Donc, en Nero, si tu as, par exemple, 2 heures de vidéo que tu veux graver en disque, il faut choisir un modèle qui utilise un « bitrate » (débit) de 4000 kbps.
Si la place de laquelle tu parles est sur ton DD, il faut ou déinstaller quelques programmes ou acheter un DD plus grand.
Il me faut ajouter qu’inclue dans le processus de ‘graver’ sont (1) graver un disque ; (2) graver un fichier .ISO ; et (3) graver un dossier DVD (Video_TS et, quelquefois, Audio_TS). Donc, quand nous (TDK et moi) avons dit que tu essayais de graver directement, nous voulions inclure toutes ces trois possibilités. Il faut tout d’abord convertir ton fichier .avi en mpeg-2, et puis, dans un étape totalement séparé, ‘graver’ ce ficher ou en disque, ou en fichier ISO ou en dossier Video_TS…
(Furet77 - I have already given you the properties you can use to ensure that your video will fit on a 4.7 GB DVD. ... So, in Nero, if you have for example two hours of video which you want to burn to disc, you should choose a template which uses a bitrate of 4000 kbps.
If the space you are talking about is on your HDD, you should either uninstall some programs or else buy a larger HDD.
I should add that included in the 'burning' process are (1) burning to disc; (2) burning an ISO file; and (3) burning a DVD folder (Video_TS and sometimes Audio_TS). So when we (TDK and I) said that you were trying to burn directly, we wanted to include all these three possibilities. You should first of all convert your .avi file into an mpeg-2, and then, in a totally separate step, 'burn' this file either to disc or to an ISO file or a Video_TS folder.)
furet77
TO ++Ken ++BERRY or ++TDK
Following my my concerns that I have always I have @@apercu that ++USV8 wonders me during the @@creation of an ++DVD or a file ++ISO a certain spaces ++DD .Mais I have @@apercu that the number of available ++Go on my disc corresponded not at all has not that staff on my disc and that is important enough because ++USV8 put following the @@creation of a file ++ISO or a copy on an ++DVD important enough for example for 6.8 ++Go instead of 32 ++Go
I would have well liked to put a copy of screen but I do not know how to make to it insert in this @@post
If you could help me on this @@probleme of space because I am truly novice it - over .
Thank you again on your assistance
furet77
Re
Merci je prefere ecrire en francais car je passe par un traducteur ....
Voila lorsque je veux justement c'est la mon probleme, le logiciel me mentionne que je n'ai pas assez d'espace sur mon DD alors que justement j'en ai assez apparement et la je me demande pourquoi j'ai fait des images ecran pour voir exactement ce que le logiciel indique mais je ne sais pas comment les mettre sur le post
furet77
