hi anyone
Please help me out, i have run in to problems none stop with my editing, used pinnacle for ages and that was a bad idea, now got the trial 30day of the ulead videostudio 10 and found the program a million times better and runs well, completed my editing and came to burn the DVD after checking adn making sure everything was right i burnt the DVD,
it was succesfull but when i came to watch the DVD found that the burnt contents was nothing like the edited version i had done and completed, frames were not cut in the right place the music was out of sink and so on,
Can any one surggest where i am going wrong or have i got a setting that says create a movie of your choice
HELP please
Andrew
DVD contents diff from the final cut
In order to help you we need more information. Please read the following :
Are you following the recommend procedure:
1.Capture to (most people use DV, unless you're not able to)
2.Edit in the same format, keeping the project properties the same as your video clips. Then after all editing is done...
3.Share>Create Video File to DVD compatible MPEG-2. Then and only then going to:
4.Share>Create Disc.
It seems like you are either skipping Step#3 and going into the burn module with a project in the timeline, or you are capturing and editing MPEG or some other highly compressed video format, thus giving you the Out of Sync problems.
If you are editing MPEG (hopefully MPEG-2) make sure Smart Render is not checked. There seems to be an issue (again) with Smart Render and MPEG files.
- Read This First Sticky
- Recommended Procedures
- Tutorial, From Camcorder to DVD found in our tutorials section.
