uvPL.exe on startup - what's this for?
nosnoop
Post by nosnoop »
I notice that the uvPL.exe is loaded/run during startup. Does anyone know what this is for? Can I safely delete it or disable it?
I don't want loading unnecessary programs to slow down my startup or running unnecessary background processes. That's why I have disabled programs such as qttask.exe (QuickTime) during startup.
TIA.
GuyL
motherboard: ASUS P6T
processor: I7 920
ram: 6GB
Video Card: ATI 5870
sound_card: Auzentech X-fi Forte 7.1
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: LG W2753V & HP w2408h
Post by GuyL »
It just like the Quicktime you mentioned. It is Ulead's way of cheating and making you believe that video studio loads faster than it does. They set it to preload on windows startup so there is less to load when you load the application. I've disabled it and it really irks me to no end that software companies do this.
Now using Adobe Premiere and Photoshop
Guy Lapierre
www.forefrontbusinesssolutions.com
nosnoop
Post by nosnoop »
Ahhh... That's why they are advertising this "New" feature of VS 10+:
New! Faster program start-up for the wizards and main
editor means less waiting so you can start editing right away.
I definitely don't need that; no point in slowing my every startup and occupy resources all the time just for that few seconds difference on starting the program. I will disable it.
On a related note, I really don't like Ulead's installation package which installs components such as DirectX and QuickTime without info or warning (unless you check the manual). Maybe less headache for support for new users, but they should at least give a choice of "Full" or "Typical" install for new users and "Custom" install for more advanced users.
Terry Stetler
Post by Terry Stetler »
Problem is that if you have a QT installation it may not included updated modules that the new software needs. Not always a problem, but for that 1 in 10 case it can prevent problems that would otherwise end up here :)
Terry Stetler
GuyL
processor: I7 920
ram: 6GB
Post by GuyL »
nosnoop wrote:On a related note, I really don't like Ulead's installation package which installs components such as DirectX and QuickTime without info or warning (unless you check the manual). Maybe less headache for support for new users, but they should at least give a choice of "Full" or "Typical" install for new users and "Custom" install for more advanced users.
I agree! You should be given the ability to choose what is being installed and if it is required for installation you should be made aware.
Guy Lapierre
