VS 9 Image Preferences ?
ARJRER
Post by ARJRER »
I am setting up a slide show using VS-9. The default setting to change the slide is 3 seconds. How do I change this to 5 seconds? I can't locate the preference area to make this change.
Thanks for your help.
Jim
Terry Stetler
Post by Terry Stetler »
File/Preferences/Edit;
Change "Default inserted image/color clip duration" from 3 seconds to 5.
:D
Terry Stetler
Post by Trevor Andrew »
Hi Jim
(File/Preferences/Edit) The transition default duration can be changed here as well.
Also once the images are in the timeline you can change the duration
You have to select adjacent images using shift – click
(Menu at the top) Clip-Change Image Color duration
Trevor
