When I connect my VCR to capture direct to DVD-R disk when I press the capture button I get this message:
" Cannot start the capture graph. Capture failed. The created file is corrupt and unusable. It will be automatically deleted".
Any ideas why is this happening? What should I check?
Stelios
Straight Capture to Disc
maddrummer3301
maddrummer3301
stelch
- motherboard: Fujitsu Siemens
- processor: Intel Xeon processor E31240 8 MB 3.30 GHzz
- Video Card: NVIDIA Quadro 2000 1GB
- sound_card: Realtek
- Hard_Drive_Capacity: 2 x 1 Terr
Thanks for your reply.
Yes I am using the pass through feature from my camcorder. When I want to write (the converted analog signal) on to the hard drive of my PC then it works OK. Its only when I want to record straight to the DVD disk that I have the problem.
I have also tried from the DV tape direct to the disk (as you have suggested) but I still get the same message as before " Cannot start capture graph..........etc"
What else can I try?
Stelios
Stelios
