Hi... have downloaded Ver-1 to evaluate, and have encountered a rather annoying problem that I can't figure out.
I have created an MPEG2 file that has audio on it with another application.
In DVDWS, I can see the pictures, and hear the audio - quite happily. The virtual DVD "works" right up to the DVDWS internal "player" stage.
However, when I burn the DVD (as a PAL thingy) the resulting disc has no audio on it at all.
This has happened with a couple of MPEG2 files that I have generated. However, if I make a disc with captured DV from a camcorder, there is sound - no problem.
It's obviously something in the settings of the sound of the MPEG2 that I need to resolve, but I don't know where tostart.
Any help greatly appreciated.
Skotzmun
Version 1 - No audio AFTER burning to DVD
DVD WorkShop?
Is that DVD Workshop 1.x, or DVD Workshop 2.x? Where is that "Ver-1" showing?
What are your project properties?
And where did the MPEG2 files come from? What was used to create them, and what are their attributes when you right-click on them in DVD Workshop and show properties?
George
Skotzmun
Sorry - Workshop 1.0 ("Version 1" was my interpretation)
settings - (very compressed!) screengrabs follow:
The files with problems were created using Xequte's DVD PixPlay - a programme that enables the creation of MPEG files from a stream of JPEG pictures... like I say - the resultant file has audio quite happily before ULead does its recompression on it.
HTH
Skotzmun
HTH
Skotzmun
Skotzmun
SELF-UPDATE:
I have just done a quick investigation and may have found the reason, but can't confirm it... could anyone help?
The Xequte software was set to create MPEGs with AC3 audio as standard. I changed this to MPEG2 audio, and rendered another movie.
I then created a "DVD Directory", and noticed that it puts its own copies of the video files in there (as ~filename.mpeg)... the AC3-sourced one was silent, and the MPEG-sourced one had audio.
Therefore, is DVD Workshop 1.0 capable of handling MPEGs with AC3 audio, is there something I need to checkbox, or do I need to make sure everything is made with MPEG2 audio as standard?
Thanks in advance - Skotzmun
Skotzmun
Thanks for the quick response!
Now that I know what I'm looking for, I've also found another post on the board that says AC3 is not enabled in the trial versions as Dolby want a fee (yes... that's right... the same Dolby who have just floated on the Stock Market... poor old Uncle Ray obviously needs the money
Therefore that'll be the reason... I'll stick with MPEG audio for my evaluations then!
