VOB sync issues
hhhgamewmx7
VOB sync issues
Post by hhhgamewmx7 »
Using VS8, I made a DVD with 7 titles and some titles lose sync with video half-way through where i cut ad breaks from editing. When I edit, I have made a habit of splitting audio before saving to limit errors. I nearly always have sync problems and have to be very careful when editing. I always take each section and edit it first, split audio, save and patch together and that usually works but this time I can't fix it.
Any help as to why this is happening would be appreciated.
DVDDoug
Moderator
Post by DVDDoug »
What video format are your original files?
If they are MPEG, that's a fairly common problem. A couple of possible solutons are to capture to AVI/DV format, convert to AVI/DV before editing, or get a special-purpose MPEG editor.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
hhhgamewmx7
It is MPEG. I capture in MPEG and edit in MPEG. A week of non-stop work has gone into these DVDs and its hard to see what converting to AVI can do now.
Terry Stetler
Post by Terry Stetler »
Please understand that if the MPEG is captured with consumer gear, Main Profile @ Main Level, and not HDV it was intended to be a distribution format for VCD/SVCD and DVD, not an editing format. As such editing with it is iffy at best.
Yes, a lot of products support doing this and there are cameras that shoot MPEG direct to DVD, but that doesn't make it a 'best practice'.
You'll get far better results if your hardware permits you to capture in DV or analog compressed with a proven editing codec like MJPeg (I use Morgan-Multimedia's or MainConcept's, both <$20 and with long free trials).
Other options are the free HuffYUV (get ver. 2.20) or the QuickTime 'Component' codec (built into VS and MSPro). Both are lossless, but at 10-12 MB/second create huge files.
If stuck with MPEG sources that need editing my procedure is to convert them to a format that edits better; usually MJPeg set to a high quality setting. MJPeg set this way can be nearly lossless, a big advantage in the edit bay and when you go to encode.
This is called using an 'intermediate codec' and is a common practice when editing lossy sources, especially MPEG.
Terry Stetler
jchunter
Post by jchunter »
hhhgamewmx7,
Video Studio version 8 had chronic video/audio sync problems, this was fixed in version 9. The solution is to upgrade to version 10+, which is the current version.
