Hi, first post here, so sorry if I'm being thick!
My monitor, actually a projector, has a res of 1280 x 720.
VS10 wont launch, saying that I need a res of 1024 x 768 min. Trouble is, reducing the res means the top and bottom is missing from the screen, and also gives distortion and stuttering on playback.
I got this to go with my new HD Sony HC3- Surely there's a setting for VS10 in the now standard 1280 x 720 HD resolution?
VS10 is still on trial, I like the program but messing about with my pc's res every time I use it doesn't seem right- my other Ulead products don't have this problem?
VS won't launch on my monitor res!
mikeaitch
Thanks for the reply
Setting that resolution every time I use one program is a bit much though, and as the projector has a 16:9 ratio I only have the option of displaying it natively with no scaling- leading to the top and bottom being clipped off as it has only 720 lines available , or scaled to fit the panel, in which case everything is distorted to fit the 16:9 shape as 1024 x 768 is 4:3 shape
I can't be the only one with a HTPC and projector- seems like a glaring omission to me.
