RENDERING INvIDEO STUDIO 10
Peter
Hello Trevor
I hope you tried it and it worked OK for you please let me know.
Here is the information you requested about the inported file.
Original on DVD disc is:
Number of Audio streams=1
Number of subtitle streams =0
TV System 625/50 PAL
Atribute 24 bits 720 x 572 16x9
Frame rate 25 frames per sec
Data rate = variable bit rate (max 8000kbps)
Total length 40 mins
When the DVD/VR is imported the properties of the imported file are as follows:
MPEG2 Lower Field First
61,823 frames
35000 frames/sec
AUDIO
LCPM
118,700.160 samples
48000HZ 16 bit strereo
Hope this help
Pete
61,823 frames
35000 frames/sec
AUDIO
LCPM
118,700.160 samples
Hope this help
Pete
Ok Peter
I had no problems.
My source DVD was created using Video Studio probably VS 8 may be 9?
The Dvd consisted of a play first video 12 seconds.
The main movie 00-30-27-10
A slide show 00-06-40-00
I used ‘Insert DVD-DvD-VR
After Parsing DVD
I selected the Titles, Three in all and then selected Import
The three files were saved to my working folder with a thumbnail being inserted to the timeline.
The properties for the first video showed:-
MPEG files
24 bits, 720 x 576, 25 fps
Lower Field First
(DVD-PAL), 16:9
Video data rate: 6000 kbps
Audio data rate: 224 kbps
Now I Share Create Video File
I do not want or need to change the properties so I select —Same as First Video Clip
This rendered the three files into one using the properties of the first clip. The process took about 10 minutes.
If your render process is not relatively fast then you may be changing the file properties.
The total time of the project and the rendered file was exactly the same at 00-37-19-10
I played the four files using several media players on my pc.
There is no indication of any quality problem or out of sync’ audio.
One thing, your settings above indicate 35000 frames/sec, I assume this to be a typo error.
Trevor
I had no problems.
After Parsing DVD
MPEG files
Lower Field First
(DVD-PAL), 16:9
Trevor
Peter
Reply from Peter
Thanks for you help Trevor, I did exactly the same as you and it still came out corrupt ,
However I did it sucessfully by rendering it in just PAL-DV instead of PAL DVD and it worked fine,
I cannot understand why it works fine in all rendering "modes" in VS9 but not 10 using exactly the same clips and settings ,
There must be something on my computer that it intefearing with VS10 and not VS9 which is weird but possible I suppose as I notice the project made in VS9 are not compatible with VS10 so there obviously is a difference.
Peter
Peter
