I'm trying MovieFactory 5 and have one problem, that I didn't have with version 2 (german).
When I import demultiplexed movies (MPV+MPA), the program always wants to recode the movie. When only using the MPV part, this problem doesn't exist.
I've checked the box that says "Do Not Convert Compliant MPEG files" and I'm sure they are compliant.
Here the details (translated from german version):
MPEG-Files
24 Bits, 720 x 576, 25 fps
(DVD-PAL), 4:3
Video data rate: Variable (Max. 7000 kbps)
Audio data rate: 224 kbps
MPEG-Audio level 2, 48 KHz, Stereo
Can somebody tell me how the get the same results as with version 1?
Regards
data68
MovieFactory5 always wants to recode the movies
data68
It's a PAL project.GeorgeW wrote:Is your project PAL or NTSC
Yes. Source is a TS stream, demultiplexed with "ProjectX" and cutted with "Cuttermaran".Also, did you do any editing of your source videos
Did it, but nothing changed.Try a small test project without motion menus or menu transitions turned on.
Thomas
twiggman
