Renaming a "Save Trimmed Clips"
jimswinder
motherboard: MSI MS-7a59
processor: IntelR CoreTM i7-7700K CPU 4.20GHz
ram: 16.0 GB
Video Card: NVIDIA GeForce GTX 1050 Ti
sound_card: NVIDIA AVermedia C727 PCle HD Capture Device
Hard_Drive_Capacity: 5640 GB
Monitor/Display Make & Model: 2 Samsung T24C550
Corel programs: Video Studio 2018
Post by jimswinder »
Is there a way to "RENAME" clips when I do a "Save Trimmed Clips". I have all these clips that now have all the same name as the original video thery were clipped from...
jimswinder
TDK1044
Post by TDK1044 »
Sure. Just click in the text field under the icon...hit backspace to delete what's in there and enter your file name.
Terry
jimswinder
ram: 16.0 GB
Sheesh...don't I feel stupid!!! I was doing a right mouse button and looking for the typical "RENAME"
THANKS!!!!
jimswinder
Post by Trevor Andrew »
If you are looking at the library, renaming these thumbnails does not rename the files on your hard drive.
Trevor
jimswinder
ram: 16.0 GB
Ok Trevor..you bring up another question. I used the "Split by Scene" option under CLIP and it placed all the different scenes to the library. Is there a way to get all thsoe scenes to my hard drive now? Independent of the current project?
jimswinder
Hi Jim
When you look at video studio, the clips in the timeline, the clips in the library., all the clips you see are only thumbnails representing the main file saved on your hard drive. The clips are merely links to the main file.
Editing the clips in the timelines or library does not change the files on your hard drive.
When you Split by Scene video studio provides pointers, locations to parts of the main files, these are represented as clips in the library or timeline. If you right click the clips select properties the save location will be the same for all Split by Scene clips.
You say (Is there a way to get all thsoe scenes to my hard drive now )
These scenes are already on your hard drive as the main file captured I assume earlier.
Once you edit the project, you make a new file by Share Create Video File.
If you need to make a separate file for each of the scenes, then click a scene, Clip—Save Trimmed Video
This will render the clip to a separate file saving it in the ‘working folder’
Hope this Helps
Trevor
tommytucker
So saving a still from a video
Post by tommytucker »
I see it appear in the library...but where on the computer would the new JPG or BMP saved still reside...working folder?
Normally, it is the working folder you set in File > Preferences. But you only have to right click on one of the files, select Properties, and in the box which appears, the file name and location will appear at the top...
