Add effect to overlay?
Danii
Post by Danii »
Is it possible to ad an effect when an overlay appears?
daniel
Post by daniel »
you can have fade-in, fade-out, move in from all eight directions, move out to all eight directions, or use most if not all (never tried them all) video filters including crop etc.
You can also have them rotate while they come in.
The only thing you can't do is have Transitions between two adjacent overlay clips.
Oh and I forgot, you can surround them with a choice of 14 different masks. You can also modify transparency and add a border.
See the Attributes Tab
Danii
Post by Danii »
Ok thanks but when they move in from directions is it possible to make it go faster?
daniel
Post by daniel »
using the blue arrows under the preview window you select the time it takes for fade-in, still phase, and fade-out.
edit: read that as effect in, stable phase, effect out
The same as for all transitions, title effects etc
Post by Black Lab »
You actually can do this, but in a roundabout way. In a new project, put your clips on the main video track and add your transitions. Render that to a new video file. Now go back to your original project and add that video file to your overlay track. Voila. :wink:
daniel
Post by daniel »
True, but then if you want to cheat that way, you can do it even better.
Don't make a video file, just save the project with the transitioned overlays and then insert that VSP on the overlay track.
This way you don't have to render twice the same image/video.
Doing it repeatedly is as close to nested timelines as you get.
Post by Black Lab »
Aha! :D
Joe Louvar
Post by Joe Louvar »
Neat tip, thanks. :D
