Question on file format as I drag them into timeline
tommytucker
I have some FLV footage from YouTube that I am incorporating into a project. I am using SUPER@ to convert these FLV files to something VS can read. I have several options...AVI, MPEG 1 through 4, Ogg, Vob, Mov. If you are moving some stock footage into VS, what is the best format for the program to handle?
heinz-oz
tommytucker
Okay..so AVI?
There is no conversion setting for DV anything on Super@. There is avi....will try that setting.THANKS!
I agree. If you are making a DVD, you might get away with MPEG-2 since your DVD is going to end-up MPEG-2. But I've had some trouble with MPEG.I personally prefer DV-AVI.
I would avoid MPEG-4, Xvid & DivX like the plague! I've never played-around with that stuff myself, but the posts on this forum indicate they are bad news! (These formats are probably OK to play-back on your computer, but once they are encoded it's best not to edit or re-code them.)
Give it a try. As a "sanity check", an AVI/DV file will be 13 GB per hour (216 MB per minute). I don't know anything about the YouTube format, but your original file is going to be much, much smaller than that.There is no conversion setting for DV anything on Super@. There is avi....
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
- ram: 2 GB
- sound_card: Intel GMA 950
Re: Okay..so AVI?
With Super@ you have to make 2 selections.tommytucker wrote:There is no conversion setting for DV anything on Super@. There is avi....will try that setting.THANKS!
The first selection box is "Select the Output Container" with 27 choices one of which is avi.
Having made that first choice you then select the output Video Codec.
The list varies dependant upon the choice made in the first selection box.
When you select avi in the first box you get the following choices in the second:
- Asus V1
- Asus V2
- Divx
- H.263
- H.263+
- H264/AVC
- Flash Video
- M-JPEG
- MPEG-I
- MPEG-II
- MPEG-4
- MS-MPEG4-V1
- MS-MPEG4-V2
- XviD
- huffYUV
Most of the above listed codecs are described in the wikipedia encyclopeadia
