Saving to DVD folder
girly
Post by girly »
When trying to save a VS10 project to DVD folder I get a message stating 'convert has some problems'. I have already rendered this to a disc in the past but did not save it to folder.
Thanks for any help
Post by Trevor Andrew »
Hi Girly
A Dvd folder is created within the final burner window.
This contains a TS folder that contains the video and all menus.
I use this folder to check and watch the finished movie, using Power Dvd.
At this stage you should be using an mpeg file, you indicate that you are using a project (vsp) file.
A guide to the workflow:-
Capture
Edit
Share Create a Video File (Pal-Dvd)
New project (using the same settings)
Share Create Disc---Add Video File, the one created above.
Continue to make menu’s
In the last window you can choose to
Create a dvd Folder
Create a disc image
Burn a disc.
Trying to render the project within the burner causes many users problems.
Does this Help
Trevor
girly
Post by girly »
Hello Trevor
When I have edited my video and am ready to burn I go through the process you say - Create disc etc and usually everything is fine. I also at the same time choose to create a DVd folder which as you say contains TS folder.
I am trying to save a video I have already burned to disc that I didn't save to a DVD folder initially but I get the message 'convert has some problems' but don't know why as I haven't changed anything from the initial burn. Hope you understand.
girly wrote:Hello Trevor
When I have edited my video and am ready to burn I go through the process you say - Create disc etc and usually everything is fine. I also at the same time choose to create a DVd folder which as you say contains TS folder..
Just to confirm when you have completed the edit, the next thing is Share create video File Pal-Dvd.
If at this point using the project in the burner window may cause the problems you are seeing.
Some users are ok with following this process but some have problems and render a video file first then use the video file to burn a disc.
Can you confirm that you are diong Share Create Video File
Read the Quick Guide to Dv-Avi and Quick Guide to Mpeg, from the link below
Hope this helps
Trevor
