I've used this version to create music cd's. In the past I have had NO problems until recently. Iam now hearing tack seperation noise (pops/ticks) and in a few cases the cd will not play in my home player, but will let's say in my car.
I have reinstalled the program but having the same problem.
any suggestions??
Movi Factopry 3 Disc Creator
rad
htchien
This is strange because I can burn my WAV files successfully in DVDMF/Burn.Now.
I remember in another post you mentioned if you burn to ISO image file and use Nero to burn is OK?? If this is the case, then it might be the burner compatibility problem with Ulead.
But if you are using CD-RW to burn, as I know some players do not accept CD-RW.
Maybe you should feedback to Ulead Tech Support to give them your source WAV files and tell them the burner model you use so they can help on your problem.
Ulead Tech Support Form:
http://www.ulead.com/tech/suppform.htm
Remember to use an non-free e-mail address in the form and add the virtual ts_reply@ulead.com.tw account to your safe list in the e-mail program so Ulead can reach you. This is because some e-mail programs will recognize Ulead Tech Support account as spam sender.
Hope this helps.
H.T.
Hope this helps.
H.T.
Ted (H.T.)
rad
htchien
Can you use other burning softwares to burn??
If it still pop noise when you use other burning software to burn, then it's possible the power of the laser head in your burner is getting down, which will make media compatibility problems with players....And that means you need to send your burner back to the seller to get it repaired or buy a new one.
Hope this helps.
H.T.
Hope this helps.
H.T.
Ted (H.T.)
rad
I just created another cd with burn now, I extracted songs from a "real" cd, there is NO track seperation noise so Im guessing it's not the burnner.htchien wrote:Can you use other burning softwares to burn??
Hope this helps.
H.T.
the other project in question I use Sound Forge to create tracks, mix & edit and from there I export into Burn Now. After I burn from that, I get the noise...so I'm guessing it's Sound Forge....I'm guessing
