Thanks in advance!
Fading an Image
thewifey
Fading an Image
I would like to take an image, fade it out and use it as a watermark. However I can't figure out how to do this. I'm using PhotoImpact 8.0
Thanks in advance!
Thanks in advance!
thecoalman
3at1ce
Ok , I am trying to do the same thing...make a watermark out of my logo...I can change the transparency but when I save it , it either saves it transparent but with a white background or it saves it not transparent like I had it set...I have PI 7...what on earth am I doing wrong???
Thanks so much
Dana
Thanks so much
Dana
MikeGunter
Hi,3at1ce wrote:Ok , I am trying to do the same thing...make a watermark out of my logo...I can change the transparency but when I save it , it either saves it transparent but with a white background or it saves it not transparent like I had it set...I have PI 7...what on earth am I doing wrong???
Thanks so much
Dana
Save as a PNG with transparency.
Mike
thecoalman
That transpaqrency only works within PI and the image your woking with. You can't create a transparent objects to include in other applications. You can trick people into thinking it is by using the same color background.
You can however createa transparent background where only the objects are visible see this thread. http://phpbb.ulead.com.tw/EN/viewtopic.php?t=830
3at1ce
Hi Coalman
yes that was me on the other thread that you helped!! Thanks!! In fact that is the image that I am wanting to make a watermark out of.
So are you saying that I cant make a watermark out of my logo without the white background...the logo I'm starting with is the one that I took the background off of (the other thread)
