Effect's
Cumbrian
Effect's
I am new to VS10+.I have a Slideshow with over a 100 photos,i want to put the same Effect between each photo,is there a way i can do this in one go.i am dragging the effect between each photo one at a time.I am going to be here ages doing it this way.A exellent forum here and thanks for any help.Cumbrian
Hi Cumbrian
File – Preferences- General tab
Select ‘Use Default Transition Effect’
Select an effect from the drop down box..
File Preferences- Edit tab
Set the default transition duration
Each image/video inserted will have the transition effect auto inserted.
Once images are inserted to the timeline you can change the duration of selected images by using ‘Clip-Change Image/colour duration
Hope this helps
Tip if you double click an effect it will be inserted to the first available space in the timeline.
Trevor
Hope this helps
Trevor
