USB vs. Firewire
garyrobb
USB vs. Firewire
Post by garyrobb »
Will I get as good results using the USB connection that came with my camcorder, or do I need to upgrade the connection to Fierwire for VS10?
GeorgeW
Post by GeorgeW »
What make/model is your camcorder :?:
If they supply the drivers/software to successfully transfer dv .avi via USB2, then you should be able to continue to use that connection (although most folks transfer dv .avi via firewire).
I'm not sure if the dv-to-mpeg capture will be available using that sort of transfer protocol.
George
maddrummer3301
Post by maddrummer3301 »
