Importing MPEG files takes for ever
Scorpion
Post by Scorpion »
Importing video files from my hard drive is taking forever. I select one from the 'Selection' dialog and my system appears to lock up or just takes a long time to add it in.
Is this normal, or is there a configuratation I can hack to speed this process up?
Any help would be appreciated!
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
This is not normal.
I regularly import a full dvd, 4gb of mpeg files into WS and it takes maybe a second to do it.
Sorry I'm not sure why yours aren't working properly, except for,
Are they on the same drive or a slower one, the Mpeg file is actually corrupt and so won't import properly....
Scorpion
Post by Scorpion »
Thanks, it may point more towards my rig.
THe MPGs do get in there eventually but it takes an anoying amount of time.
Devil
Post by Devil »
What are the characteristics of your MPEG files?
If they are MPEG-4, I would guess that what you are experiencing is perfectly normal. If they are MPEG-2, then what are the A & V bitrates, GOP etc.?
You are asking us how long a bit of string is. Unless you tell us the whole story, we cannot write the last chapter.
Scorpion
Post by Scorpion »
Thanks for following up.
I'm using GSPOT for this information and the MPEG information that comes back is this.
Container
MPEG-2 Program Stream << { 1 vid, 1 aud }
Sys Bitrate: 15000 kb/s VBR
Audio
MPEG-1 Layer 2
0xc0:48000Hz 192 kb/s total (2 chnls)
Video
MPEG-2
480x480
Frms/Sec
29.970
NTSC
4:3
File Size
1.23 GB
Is any of this helpful?
Thanks!
Devil
Post by Devil »
Your problem is almost certainly due to the enormous bitrate. The unusual 480 x 480 format may exacerbate it, as this is not 4:3. You should set the WS2 project to similar to the incoming format, but 15,000 kbit/s is well outside the acceptable range. What is happening is that WS2 is trying to change, on a frame-by-frame basis and convert it to something usable.
I suggest you try with your input files as 704 or 720x480 and, most certainly, a bitrate of <7000 kbit/s CBR or maximum VBR, to ensure maximum compatibility.
