DV Scan Digest
bleb
DV Scan Digest
Post by bleb »
I noticed the Scan Digest HTML report in VS 10 + displays a field named ATN (see paste below). Can anyone tell me what it means ... is there a correlation to elapsed time?
In:0:00:00.04
Out:0:00:05.14
(0:00:05.10)
ATN 328 - 3758
Hi Bleb,
The Scan Digest is a log of your Quick Scan. I've only used this once, just to test it. There is no reference to this in the Help(less), file or Manual. I've long since deleted my Scan Digest Log.
What I read from your post is that you trimmed 4 frames off the beginning (Mark-In). The end of the video clip is 5 secs and 14 frames (Mark-Out) and the total duration of the clip is 5 secs 14 frames. Since the first 4 frames were not actually trimmed off, then they are still there. The clip however will start playing at the 4th frame. The timecode in parenthises shows the playing duration of 5 secs 10 frames.
So far I have not figured out the ATN, however give me a few minutes and I'll run a quick scan on a short clip, create a digest and do some deciphering, with some known figures.. :shock: :?
Well, I still don't know what the ATN[/b field is. I do know that it is a progression. I ran a scan, where there were 10 scenes and each ATN numbers were sequentially increased from the previous scene.
Also as a sidenote, upon opening the hmtl file in notepad, I discovered that mine said the Application was MediaStudio Pro 8, when I was using VS10 +.
