picture as logo
houskat
picture as logo
is it possible to put a picturea as a logo to all the videos? like eg. TV stations have? how do I do it? thank you...
Terry Stetler
Yes.
Most times these will be in the form of a 'bug' (the little image in a corner of the screen) or as a 'lower third' (the strip across the bottom of the screen). The procedure varies depending on the version of MSPro you're using.
In MSPro 7 you would load the image into an overlay track (V1....V99) then apply a 2D moving path to it. Next set the moving paths options to make it stationary (first and last keyframes with the same settings), basically adjusting the Size settings to scale it and X/Y position it.
In MSPro8 you would also load the image into an overlay track, but the application of the moving path and adjusting its controls would be done in the Effects Manager.
In either case do not place the image in the exact corner or left/right/top/bottom but in about 15% of the video frames size to account for overscan, the portion that will be cut off on a TV set.
Terry Stetler
heinz-oz
Terry Stetler
Nice to be back H/O.
I put an explanation for my absense in the Mods forum if you care to read it. Basically for public consumption we had to downsize our living space because of my handicap and the complications flowed from there
Anyhow....it'll prob. take me a bit to get back in the swing and catch up on a few things, so be patient
Terry Stetler
