I wanted to add a track from a CD to my project. Ordinarily I would use some other program to rip it first, but since VS10+ says that it can directly read CD tracks, I decided to try doing it that way. Well, it hung VS10+ both times that I tried -- a solid hourglass and I had to eventually use Ctrl-Alt-Del and abort it with Task Mgr.
After that, I went back to MusicMatch to rip the track and then imported it into VS10 with no problem. But has anyone successfully used this feature?
VS10+ Hangs Trying to Rip from CD
I've used it plenty of times with no problem. You probably have a system conflict between multiple applications that perform the same task. In the same way that Video Studio may hang up during a burn if you have Nero or Roxio on your system, the same applies to capturing audio from your CD player.
Terry
