Reburning dvd movies
Toppler
Ok so this is terrible i lost my instruction manuel so i am going to have to buy another one but i just finished making a movie for my office thanks to several of you on this site THANK YOU!!!!! i won first prize btw.
I did then rendering so i saved the audio and video and such on to my hard drive but i was just wondering if there was a way i can just keep burning dvd's at a later time.
I usually open vs10 open the saved movie file and then i have to remake the menu and stuff everytime and it takes for ever is there some way to bypass the remaking menu and just have it saved so i can load the movie and burn it completed with out haveing to to remake everything?
From the Create Disc burn your movie as a Disc Image (Iso) this will create a file on your hard drive which you can burn using the Disc Image Recorder ( Start-Programs-Ulead Video Studio—VCD/DVD disc image recorder.)
All video and menus etc are preserved. Burn as many as you like(one at a time that is)
Also
When you Create Disc you can save the project as a *.vsp call it my-burn.
Opening this Vsp at a later date will show the menus provided you haven’t changed/edited the project.
Trevor
Also
Trevor
And you don't have to buy a new user manual - you can download one anytime you want from here :-
http://www.ulead.com/vs/documents.htm
NoM.O
Another option is to select 'Create DVD Folders' at the burning stage. Perhaps not applicable in your case, but aside from burning multiple copies it's a handy feature for 2 reasons.
1. If you want to shrink a slightly oversized project, programs like DVD Shrink will be able to read the folder like a normal DVD and perform the compression as required.
2. Most software DVD players will be able to play the folder like a DVD so you can watch it back to check for errors (you can do this with an ISO file as well, but it will require an extra disc image mounting app like Daemon Tools).
peace.
peace.
hagadorn
Yes you can use a program like nero to copy your discs.
I prefer to use Video Studio for all my burning, where I can.
You do not have to create an iso first but I find this approach best.
Creating an iso takes about the same as burning a disc using VS.
Once created burning a disc from the iso seems much quicker.
As an example it takes about 10 minutes to burn a 4Gb iso.
Obviously this is dependent on your pc system.
I always burn at a low rate 4 x max
Creating a TS folder allows me to view the complete work using Power Dvd prior to burning the disc.
Trevor
Trevor
heinz-oz
I always create the DVD folders and archive these. This approach has a few advantages over the ISO image as far as I'm concerned. The best part is that I can use DVDShrink to size down this folder if I overshot the target size. This happens frequently since I use 2 pass encoding and always aim high with my bit rate. Another one is the ease of extracting part of that video from the VOB files if I find later on I want to use some of it. It's not that easy with ISO. Taking it of a burned DVD would work also but I tend to leave the burned DVD well alone and don't use it for anything but playing on the DVD player. All disk blank have errors on them, burneing data adds a few more, replicating the disk is likely to add even more and chances that this will be fatal increase.
Toppler
