Disabling Write-Behind Caching in WinXP
stagman
Post by stagman »
Hi all, i got Videostudio 8 with my DV-IEEE1394 capture card, installed ok and can capture/edit/create video files and DCVs. But, when 2 out of 8 files on DVD go out of sync with video/audio and video jumps, i checked my pc settings as in user guide. All was ok but I couldn't change 'disabling write-behind caching' as instructed as the option was 'greyed out'. So I went to :
'My Computer>System Properties>Advanced Tab>Performance Settings>Advanced Tab>'
and changed Memory Usage from Programs to System Cache. The reason for this is if you click on Help for these 2 options, it is explained that for Programs memory uses XPs default cache but for System Cache, memory uses a larger cache for programs that need it. Have I done right or is there another reason for this intermittent video corruption. Please don't say upgrade to ver 9 or 10. Cheers :D
maddrummer3301
Post by maddrummer3301 »
Last edited by maddrummer3301 on Sat Feb 03, 2007 5:02 am, edited 1 time in total.
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
write behind cache
Post by Ken Veal »
stagman
Post by stagman »
Can you :D post how you created the mpeg2 files and burnt the dvd?
The captured video (dv.avi) files played correctly?
If you edited MPEG2 video files using VS8 then I would suggest give up editing mpeg2 video files using version 8 and upgrade to 9 or 10+
MD[/quote]
The mpeg2 files were created by changing Project Properties from avi to mpeg2 24bit, 720*576, lower field 1st.
Ultra DMA 5- Ultra100 is enabled on my SPP/IGP ATA controller (by default).
I've doubled my swap file paging size to the maxm allowed - 1536Mb
( 512 RAM).
I noticed that some files were 16:9 format and a couple 4:3. I've changed them all to the latter and I've yet to make another DVD.
As I said, I'm reluctant to upgrade unless there is conclusive necessity.
Cheers,
stagman
Re: write behind cache
Post by stagman »
Kenneth Veal wrote:see if this post helps
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=15677
Cheers, Kenneth, I'll check all these. BUT I only have one 200gb HD and I couldn't disable 'write-behind cache' as the option was 'greyed out'. I will delete the temp and convert files, though and retry now I've corrected the 4:3 format as posted above.
Thanks for replying,
:D
Ken Veal
ram: 32 GB
write behindcache
Post by Ken Veal »
are you sure that you double clicked disc drive and then choose your hard drive (normally C:) after going to device manager?
stagman
Re: write behindcache
Post by stagman »
Kenneth Veal wrote:are you sure that you double clicked disc drive and then choose your hard drive (normally C:) after going to device manager?
Yes, I did, Kenneth. It's greyed out.
Following on from my previous reply and 4:3 and 16:9 aspect ratios.
After making them all the same (4:3 in this case) - DVD video problem gone!
Thanks for your help guys.
kebrinton
Post by kebrinton »
All versions of VideoStudio have had this problem or that. There's no guarantee that upgrading will get rid of problems. VS8 worked fine for me, to the point where I hesitated long before actually moving on to VS9. I like VS9 better, but not because of "lack of problems" but rather for certain features.
